[970] bug ventilation
grepthis
Panamera : 970.2 4
Re: [970] bug ventilation
Message par grepthis »
Thanks guys - I will check the fuse. No, it doesn't work after turning off for a while and then back on. :-(
grepthis
Panamera : 970.2 4
Hi All,
Ok, so I think I have figured it out. It actually seems to be designed that way.
Basically, the air blows and gets faster as I turn up the air with normal Air Con turned on. It just doesn't blow really cold. When I turn on Air Max, it starts blowing really cold air and works great.
My issue is that I would like really cold air but be able to turn down the power of the blowing air. That just doesn't seem possible because with Air Max, you can't adjust it.
Cheers
Kurt
Membre depuis : 10 ans 4 mois
Things you could try is to activate "center cooler" and set the blowing climate style to "soft" and see what happens.
One weird thing that happened to me was about the smartphone attached to the driver center vent orienting the cold air flow to the temperature sensor (located right from the wheel) and fooling the actual interior temp. I had to attach the smartphone to the other center vent (passager side) to get back normal A/C behavior. :langue3:
grepthis
Panamera : 970.2 4
Thanks for the tip! I would bet that is the problem. It is not set the way I would expect it. I will check and post back. Thanks again!
Kurt
grepthis
Panamera : 970.2 4
Well, it now works normal every time I get in. Basically the settings are ok but the AC function had to be turned off and then turned on again. Now I don't have to do anything and I get cold air and can adjust as expected without having to turn on AC Max.
Thanks all for the help.
Have a great night
Kurt
waka76
Membre depuis : 7 ans 9 mois
Message par waka76 »
Dans ma Panamera, je trouve qu’il n’y a jamais vraiment de ventilation. Sauf en mettant à fond, ce qui génère un vacarme horrible, on sent pas vraiment l’air qui sort des buses. On dirait plutôt une sorte d’air pulsé comme dans une cabine pressurisée.
Faites-vous le même constat ou dois-je m’inquiéter pour ma ventilation ?
C'est vrai qu'on ne sent pas tellement l'air. Mais c'est pas trop ce que l'on demande à un système de conditionnement d'air, c'est son efficacité. Et je dois dire que de ce côté-là nous sommes plutôt bien servi.
Membre depuis : 7 ans 2 mois
C’est efficace et silencieux je trouve
Une des particularités de la Panamera c'est la présence d'ouies de ventilation diffuses situées au dessus de la planche de bord. Cette diffusion d'air permet diminuer l'effet de courant d'air des buses principales.
Il y a quelques réglages possibles via le menu de l'ordi de bord, comme celle de couper la ventilation diffuse ou de renforcer le froid depuis les buses centrales. Il est aussi possible de sélectionner 3 modes de ventilation : faible, moyen ou fort. Si ce mode est placé sur fort, alors pour atteindre une même température, le vitesse de ventilation sera plus élevée.
nathanjo
Membre depuis : 6 ans 6 mois
Message par nathanjo »
Khan a écrit : 22 août 2017 18:38 Aujourd'hui un truc bizarre : je revenais d'une balade de 250km en famille dans l'arriere pays : départementales, cols :super: , balade à pied, picnique, bref le pied :levitation:
De retour sur l'autoroute, je commence a avoir plutôt chaud : 30 degrés dehors mais 22.5 au niveau reglage de la clim : et pour cause : la ventilation tournait mais tres peu d'air sortait par les bouches d'aérations dans l'habitacle, quelque sois le reglage (automatique, mono, ...) :mur:
La variation de la ventilation fonctionne elle aussi mais hormis le bruit qui fait penser que ça souffle et bien rien :mrgreen: .
Je sors de l'autoroute, en profite pour faire une course de 5 min et quand je redemarre tout fonctionne :clap: .
Bizarre ce truc . 8|
Bonjour
j ai exactement le même problème
sur ma 2009...
Est-ce que quelqu'un a trouvé la solution?
